Loading Parquet using TimeXtender classic (dynamics fo synapse link)
I'm currently loading Parquet "tables" in TX Classic with the following setup:
  • Using Synapse Serverless to read Parquet files and expose them as external tables
  • Connecting via SQL Server authentication
This works, but I’m looking for a better approach.
Is there a way to read Parquet "tables" directly in TX Classic? The Enhanced Data Source seems limited to reading or aggregating files, not treating them as tables.
Alternatively, could I replace Synapse Serverless with Fabric Serverless? The main blocker is authentication—TX doesn't appear to support SQL providers with service principal (OAuth) authentication, only SQL Server authentication, which we’d prefer to avoid.
Any suggestions, recommendations or workarounds would be appreciated.
Hi ​@TX_Dave
The Parquet provider has the same connection options as all the other file based providers.
Connection Settings
It is the same method in the portal version as the classic version only the menus look different.
It reads a file and converts it to a table.
Your synapse question about using options other than SQL Authentication can be done like so.
Also whether SQL or this is more secure I don’t know. Once the client id and secret is added there is not much difference in how it can be used compared to using a SQL authentication option or a Azure Password option.
  • 702 replies
  • May 14, 2025
when you say “treat as tables” I take it you mean something like reading delta lake structures (i.e. many parquet files combined to form a table-like structure) or do you mean being able to query parquet like the SQL Analytics endpoint for Fabric allow you to do?
You should be able to use the normal SQL connector and Entra auth to connect to Synapse Serverless as far as I am aware. You may need to filter out synonyms (that used to be an issue).
Fabric SQL Analytics endpoints behave like SQL server except for the fact that Fabric manages the synchronisation to the underlying resource and that may be out of date by some minutes. Fabric SQL is basically Azure SQL DB serverless.
  • 1095 replies
  • May 14, 2025
Hi ​@TX_Dave
Connection Settings
  • May 14, 2025
Thank you, this was exactly what i was looking for.
I’ve considered the OLEDB provider, but the field Authentication did not have a dropdown.
Now ive put in the string ‘ActiveDirectoryServicePrincipal’, i can easily connect to synapse or fabric sql endpoint using SPN.
Now I have some new options; thanks!
  • May 14, 2025
One more question though, now i am reading up on the subject:
Provider options to connect TimeXtender to a SQL Server Data Source – TimeXtender Support
The link provided states the SQLOLEDB provider is old.
And I should use the ‘CDS (Custom Data Source) provider for SQL’
But cant find any documentation how to setup this CDS?
Should i just continue using OLEDB?
