MS Graph API Group and Group Members do not always return the Group Id
  • March 28, 2025
  • 41 views
I am extracting data from the MS Graph API using the REST connector in TimeXtender. The issue I am facing is that I can easily retrieve the members of the groups but unfortunately, the GroupId is not included in the Query and I do not see any way to include the {id} parameter into the saved results.
If anyone has solved this, can you please help with some information on how to solve this?
Best answer by nmo
I have done this by adding a static node where I set the value to my dynamic parameter - like this:
  • 24 replies
  • March 28, 2025
