Oracle Data Source using API
  • December 21, 2024
  • 47 views
I have a customer for whom with PoC, we need to connect Oracle Data Source using API. Need help on either documentation Or how to connect the same. Anyone has experience to connect, please share.
Hi ​@pkaustubha I have not tested connecting to Oracle via REST API. Please consult Oracle’s REST API documentation and then fill out the properties in TimeXtender REST data source as required:
HI ​@pkaustubha
Is there a particular reason you would like to connect to Oracle via REST instead of using the TimeXtender Oracle Data Source?
  • 17 replies
  • December 24, 2024
Hi Christian,
The Vendor whose application is used by customers does not provide access to Database Directly. They are only allowing to interact with Database using API. Need your help on how to connect the same. If there are multiple options, please suggest.
