How can I use tables from TimeXtender Data Integration in TimeXtender Data Quality?
  • April 7, 2025
  • 35 views
Dean
Starter
I am currently working with TimeXtender Data Integration and would like to leverage the tables created there within TimeXtender Data Quality. Could someone provide a detailed explanation or step-by-step guide on how to achieve this integration?
Best answer by philippus.asefaw
you have got to add Data Providers in your Data Quality System.
There is a walkthrough by Christian for it:
The integration of both tool is a bit misleading in regards to actually getting to your data, as you are able to integrate your Timextender Data Integration Execution Packages and Processes for the Orchestration part:
but to get to your actual data you have to set up a connection by connecting directly to your Warehouse!
Hope this helps.
Hope this helps.
