Using TX as a source to Dynamics 365
  • March 25, 2020
  • 61 views
We are currently using TX to stage and merge multiple source systems to create a master list of items, customers, vendors, Open AR. Open AP, etc.  Currently, we are using the Data Export on the Semantic Layer to dump out entity data so that it can then be read in by D365 as delimited text files.  I am wondering if anybody knows if there is a way to direct connect to D365 so that TX serves as a source to a D365 system?
Thanks,
Greg  Laymon
Best answer by jens.mikkelsen
Hi Greg.
Due to the infrastructure around D365 it is not possible, see the link.
https://community.dynamics.com/ax/f/microsoft-dynamics-ax-forum/254192/can-i-insert-data-from-sql-query-in-ax-table/710322
Regards Jens Jørn
Hi Greg.
Regards Jens Jørn
