Execution package nests itself?
  • February 16, 2024
  • 141 views
sierd.zuiderveld
Hi all,
We experience a weird issue where our execution package seems to run itself? This happens for a total of 3 times in the execution. Then, when it succeeds it'll kick off the next package where it will happen again.
This just started to occur in the past week, before everything worked normally.
Has anyone else experienced this?
This is the setup of the package.
Any help would be appreciated.
Hi @sierd.zuiderveld
In general, you should not exclude areas, instead exclude individual tables or possibly an perspective.
Instead change the perspective to only run what you want. The whole idea with using perspectives is that you can run only the parts needed for a SSL, which excluding DSA and MDW would negate.
Run the scale DB option on its own and then run this on success of this.
This is because of the merge steps option. If this is set it will start executing the tables while running the powershell script. Running it without Merge steps will make the normal execution slower for the other parts.
Still I do not see those things as what causes the issue.
Look at what starts this package, a job likely, and see if it will do the same if you manually start the execution package.
  • 1094 replies
  • February 16, 2024
  • 231 replies
  • February 16, 2024
Try it without the “Retry Step” option
Hi @sierd.zuiderveld did you get a chance to try the suggested solutions above? were you able to resolve the issue?
