Exercise: Automate Suggested Constraints - Error
  • February 20, 2022
  • 20 views
When I do 1 on the exercise, I get a pop-up information message "No constraint suggestions are available"
  1. Right click DSA node and choose Automate -> Add Suggested Constraints
Don't know how to resolve this?
Hi Jonas
Constraints are primary keys and in some cases the relations between tables.
If you set the primary keys manually or similarly sets this before hand you will get no changes.
Can you confirm that the source has some fields with specified primary keys or relations that do not get found by doing this?
  • 1168 replies
  • February 25, 2022
Hi Jonas
