Answer
How do I "reset" Orchestration
  • February 4, 2025
  • 13 replies
  • 243 views
It seems that Exmon/TX Orchestration has hung in some way.
Nothing is running in the ODX
 But in TX Orchestration a job is still running and block everything else in the same package.
Is there a way for me to “reset” this manually or is this a support case?
I have restarted the ODX service but that did noting.
Hi ​@nmo ​@erik.van.mastrigt ​@thzman I have created separate support tickets for the issue you describe
Update: waiting jobs issue was resolved by deselecting instances in Execution Server Configuration and saving, and then re-selecting the instances in Execution Server Configuration and saving.
  • February 4, 2025
I am experiencing the same issue so I assume it must be a general issue
Mine is stuck on execution of a prepare instance
Hi ​@thzman ​@nmo
Can you please try to stop the execution or flush the queue? Does this resolve the issue?
To do so please select Process Management
And then select process queue
  • February 4, 2025
I have tried to to use both functions several times without any results.
I have also tried to restart both ODX and execution services.
No jobs are running, and it seems to run fine if I start the jobs manually in the TimeXtender desktop client
  • February 4, 2025
I have restarted the ODX service, but I have no such option under Exception Manager in the portal (no small triangle on the side of the menu item).
Probably because we are using the free version?
@nmo ​@thzman the product team has informed me that this is an intermittent error, which should now be resolved. The product team is currently investigating the root cause of the issue.
  • February 12, 2025
@Christian Hauggaard
I had the exact same issue happen tonight again.
The proces got stuck on the execution on the same MDW as last time, even though the MDW execution package completed in the regular time when viewed through the TimeXtender client.
Only difference is that this time I am not able to restart the remaining steps through the Exmon map, but rather I need to manually start them through the TimeXtender client
I am still unable to stop executions or flush queue in Exmon
erik.van.mastrigt
We had this last week too, and facing exactly the same issue today. Process in Exmon hangs while the execution package has finished hours ago.
Flushing the queue does not seem to work. There are still packages from last week in our list that has been stopped/flushed before.
  • February 12, 2025
Having the same issue today again. Was uncertain if it was due to me upgrading to the latest version yesterday but I suppose it’s not then. I’m having the additional issue that the jobs are in a “waiting” state so I can’t even start them manually. Have run the service configuration multiple times but to no avail.
Restarted the server the services are running on and ran the configurator again.
Now it looks like this:
What is happening here?
Exmon still looks like this:
  • February 12, 2025
I am wondering if it could be related to running on the previous version of Exmon?
I am still on 24.2
erik.van.mastrigt
I am still on 24.2
We’re running on 24.3.0.49 and facing the same issue.
  • February 12, 2025
Same version here:
  • February 13, 2025
How do I fix these jobs stuck in “Waiting”?
I’ve run the execution service configuration a number of times but it doesn’t do anything.
I’ve uninstalled all old version of the execution service
I’ve restarted the server twice.
I even installed the execution service on another server to forcefully move the locks for these jobs.
Feels like I’m running out of options.
