We would like to be able to set specific schedules for our different environments. For example som execution packages could run on schedule in our QA environment during testing. And the TXDictionary should run on schedule in all environments.
Page 1 / 1
You can add an environment parameter and create different execution packages with different schedules and then add a condition on the packages where vEnvironment='Prod' e.g.
Thanks! I will try it.
Hi Martin
Like so.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
