Job stuck with state Waiting
how is it possible to have the job stuck with status “waiting”, and if I try to manually run the job, I get the error “job is already queued“
i’m running TX version 6675
Hi @gislihei can you please try restarting the execution service, the ODX service and the TX application and try again? The product team have released a related portal hot fix
Hi @gislihei I have created a support ticket for this
andrew.gebhard
Hi @Christian Hauggaard,
EDIT: updating to 6691.1 seemed to solve the issue, but maybe just as a result of the upgrade process.
I am experiencing the same or a similar issue with jobs that do not want to start:
Interestingly, I also have a job with a blank ‘State’ and an execution status of ‘Running’. There are currently no tasks in the ODX execution queue/log and no execution packages running in the effected instances.
I tried restarting the execution service and ODX Server service, and running the configurator again for both, but the statuses remain unchanged.
Kind regards,
Andrew
devin.tiemens
  • 93 replies
  • August 2, 2024
Any update related on this topic? I am experiencing the same in my DWH where I schedule/ execute jobs with the Exmon Orchestrator.
Below an example for “Waiting” status for already 2 hours.
Updated TimeXtender to the latest version 6698.1, rebooted the services and server but did not fixed this issue for me.
Kind regards,
Devin
andrew.gebhard
Hi Devin,
I haven't encountered the issues in 6698.1 anymore. Did you run the execution server configurator again?
Kind regards,
Andrew
devin.tiemens
  • 93 replies
  • August 2, 2024
Hi Andrew,
I did, but after I did it once again it is working now :)
Strange but happy that it works now, will check this the upcoming time.
Regards,
Devin
