Logging around setting "when transfer fails".
We started to use the configuration continue without data in case a transfer fails. The feature works fine, and we also see the message that one or more datasources fail. My question is, how can we easily see which datasources failed, and with what error message?
Hi Eric
We have some feature suggestions regarding this.
https://support.timextender.com/ideas/information-of-failed-transfer-of-data-sources-with-relaxed-error-handling-97
https://support.timextender.com/ideas/error-logging-for-additional-data-sources-159
So it seems like you can't actually see which table is failed. You can see that parts of an execution is failed in the execution message in the area that is marked in yellow.
  • 1079 replies
  • March 12, 2020
Hi Eric
Thanks Thomas, I will put my votes on them!
Are you aware of any workaround at this moment? If it is somewhere in the log / repository, we should be able to create a report on it ourselves.
  • 1079 replies
  • March 13, 2020
I don't think it is stored anywhere, I could not find any mentions regarding this.
JTreadwell
  • 179 replies
  • April 7, 2020
Hi Eric, you can see very very detailed execution information using this script:
https://legacysupport.timextender.com/hc/en-us/articles/360041434372-Execution-Details-SQL-Query
However I don't think the failure messages are stored anywhere unless the entire package fails. sorry.
Thanks Thomas, Joseph.
What about this logging, any idea what is being captured?
  • 1079 replies
  • June 30, 2020
Hi Eric
Depending on what CData provider you are using and what verbosity level you have added it will log all info of the authentication, synchronization and transfer.
