scheduler not working after deployment
  • May 31, 2023
  • 57 views
hi,
each time we do a deployment from DEV-PROD, the Txt scheduler is not working anymore. We use an older version of Txt (20.10.6.64) but still, the scheduler uses a wake up step that will d&e 1 table (retries=3, retries per step=3 and retry delay in min=5). If the step is successful, the next step will be executed. But since we deployed from DEV-PROD the scheduler is not starting anymore.
Have removed the Wakeup step and created a new Wakeup have reboot the PROD machine (azure) but still no result.
Can you pls tell me what needs to be done, it is urgent,
thanks!!
Mrt
Best answer by maarten.vanheur
ticket can be closed, managed this topic differently
