Setting a flag when execution is done
We use TX as a part of our value chain of systems using data. We need to programatically be able to check if the execution is done, so the following jobs can start.
I know TX can send an email when completed, but we really do not want to build the check on emails.
Does anyone have a good idea on how to do this?
Hope you can help.
Best regards
Michael Vaisgaard
Best answer by JTreadwell
Hi Michael, You can also execute packages from the command line. In which case TX will return with exit codes after completion.
see this article for more info: https://legacysupport.timextender.com/hc/en-us/articles/210439143-How-to-Start-an-Execution-Package-from-the-Command-Line
  • April 8, 2020
Hi Michael,
TX can run a script before and / or after the complete BU / DWH is processed.
You could create a simple custom table with a "Processed" and / or a "Date Processed" field that you perform a TRUNCATE against before BU / DWH processing starts and a SET or UPDATE statement against that after the BU and / or DWH is processed.
In your value chain you can then check against the status of the table. If it hasn't been marked as processed, don't start the next job yet.
We use this way of working as well for systems that depend on a BU or DWH being completely processed.
Kind Regards,
Wim
JTreadwell
