Mirgration Tool Dialog Box Question
  • October 15, 2024
  • 41 views
avanrijn
Dear Sir,
The migration Tool is giving me this dialog.
Is there anything I can do ?
Regards,
Arthur
ExecuteBulkInsertQueryStep Failed at Step BusinessUnits.Adding to table [dbo].[ODXConnects]
Violation of PRIMARY KEY constraint 'PK_ODXConnects'. Cannot insert duplicate key in object 'dbo.ODXConnects'. The duplicate key value is (47f7cfb0-0337-40bc-b508-79172aec7258, 99999999).
The statement has been terminated.
Details:
SQL Server: 'sql-instances-prod-002.database.windows.net'
SQL Procedure: ''
SQL Line Number: 1
SQL Error Number: 2627
Violation of PRIMARY KEY constraint 'PK_ODXConnects'. Cannot insert duplicate key in object 'dbo.ODXConnects'. The duplicate key value is (47f7cfb0-0337-40bc-b508-79172aec7258, 99999999). ...
Best answer by avanrijn
Hi Christian,
When I use the Migration Tool in version 20.10.53.64 I can migrate the same project succesfully.
So we don't have to look into this issue anymore, I have a work arround.
Export project from 20.10.52, import into version 20.10.53 and run the Migration Tool.
Thanx for looking into this.
Regards,
Arthur
Hi @avanrijn
As mentioned in the support ticket, it seems this error was resolved by upgrading to 20.10.53.
avanrijn
  • October 16, 2024
Hi Christian,
Regards,
Arthur
