Automate : Add suggested constraints.
I am busy with de TimeXtender Learn (TimeXtender Optimization) en there is an exercise :  Right click DSA node and choose Automate > Add Suggested Constraints.
De instruction is on TX 20.5.6.64, we work with 20.10.23.64. I can't find this function. Is that correct ?
If you are pulling data in through a Business Unit, you can set up the constraints on the Business Unit Data Source > Automate > Add Suggested Constraints.
  • 82 replies
  • October 21, 2021
In your DSA, please review table mappings.  Are those tables coming from a Business Unit or an ODX Server?
These tables are from a Business Unit. Is that the reason why we can't see that function ?
  • October 22, 2021
THANX, found it !
