Azure SQL managed identity authentication
Hi all,
My first post here. My company is currently using legacy TX but I started poking around the new version. I was a bit surprised to find out that passwordless authentication methods are not supported yet. Are there plans to support managed identity authentication in the legacy or new version?
Our company security policy requires password expiration even on service accounts so you can imagine the hazard to update them in many places regularly.
TX MDW
SSMS
Hi @azolotoiy
For some areas you can use an app to gain access.
You can use it for PowerBI XMLA endpoint
https://support.timextender.com/semantic%2Dmodel%2D109/power%2Dbi%2Dpremium%2Dendpoint%2D715#(Optional)+Authenticate+using+a+Service+Principal%C2%A0
You can also use something similar to this in the Tabular endpoint.
https://support.timextender.com/semantic%2Dmodel%2D109/tabular%2Dendpoint%2D1041
Otherwise you are right, there is no option to add it to a SQL DB ODX or DW instance.
It is something that would be a good idea to add.
  • 1092 replies
  • April 16, 2024
Hi @azolotoiy
  • April 16, 2024
Thanks @Thomas Lind , will add to ideas list
