Business Unit_ODX , Error with _R tables
How can I solve extension _R tables failing to create?
I am working on the old project Now.
This project was copied from another project repository.
Environment: Sandbox
Version: 20.10.36.64
Data Source: Business unit
Provider: SQL Server Data Source
The connection with the Data source is good and synchronized well.
When I am deploying the tables in ODX storage getting an Error.
An error occurred during create a table. See exception details for the failing object: Create failed for Table 'BSA.BSA_dbo_Inspection_R'.
An exception occurred while executing a Transact-SQL statement or batch.
The specified schema name "BSA" either does not exist or you do not have permission to use it.
Hi @sguntupalli
Can you please try deploying your schema?
Hi @sguntupalli
Hi @sguntupalli did this resolve your issue? If so please help us by marking the best answer above. Please let me know if you have follow up questions
