Error in SQL Snippet
  • January 13, 2023
  • 73 views
  • 231 replies
Hi, with this snippet:
I get an error in deploy:
The sippet it’s correct as you can see in:
Best answer by Stefan
If you remove the [] around Telefono it will work.
To visualize the code that will be used you can right-click on the table and  select Customize Code,  click Add on Transformation View and you will see that in your code you will have double [[ and ]] around Telefono. So TimeXtender actually adds them for you.
Thanks and good luck
Stefan
Stefan
  • 4 replies
  • January 13, 2023
Stefan
