Full outer join between two tables
  • 231 replies
I’ve two tables, A and B, and I want a full outter join to obtain a table C like in the image:
In T-SQL it would be:
SELECT  COALESCE(A.Id, B.Id) AS Id
       ,A.ValueA AS ValueA
       ,B.ValueB AS ValueB
FROM TableA AS A
    FULL OUTTER JOIN TableB AS B
ON A.Id=B.Id
Is it the only way to use a custom view?
I don’t know if this is entirely relevant, but here is how I got it to show what you wanted.
I made the two tables with custom data.
Then I made a Add Related Records insert. I set it up like so.
Notice that the record condition is set to not exists.
Then I related TableA and TableB with the ID field and added ValueB as a lookup to fill the data.
Here is the result.
  • 192 replies
  • October 25, 2023
Dear @rvgfox ,
In my opinion this is the only time when you really need a custom view.
If you need to ‘Blow up’  / create a carthesian product of the table by (outer) joining, because your goals is to increase the amount of records then there is no other way that I know of to do this.
Lookups never create more records in the destination table.
Hope this helps
= Daniel
  • 231 replies
  • October 26, 2023
Thanks @daniel
My approach it’s to use a “simple custom view” like this:
SELECT Id FROM A
UNION
SELECT Id FROM B
And create a table based on this view and make the lookups and transformations needed.
What do you think?
Bernarddb
  • 54 replies
  • October 26, 2023
Hi @rvgfox You could use a junk dimension table. take the id's from the both tables. and then use lookups to join the fields to the table if you don't want to keep it in TimeXtender native
  • 1091 replies
  • October 26, 2023
Hi @rvgfox
Any type of outer join are only possible in custom views currently.
When you map two tables together with the same structure they get a union behind the scenes.
It will not give the look you have in the first post, it will be like this.
Id ValueA ValueB
1 A null
2 B null
3 B null
4 C null
5 null F
6 null G
So using an custom view is preferable.
  • 192 replies
  • October 26, 2023
Personally, if I can avoid custom view I will.
For a union I would not use a custom view as this can be done in TX native.
By creating a table and mapping the fields from the table in destination columns you want them to be:
Then you can still do the lookups if you want and TX keeps tracking the data lineage and such as it normally would. Mistakes in the parameters can be made very quicky and for some views I might take a while.
In the case of a full outer join I'm not use it will work the same as unioning the table and then doing lookups though. If you need to create a carthesian product because that is what you need, then use a full outer join or a cross apply. If not, then my go to is to fix it ‘TimeXtender​​​​​​ Natively’
= Daniel
  • 1091 replies
  • October 26, 2023
Here is the result.
