Answer
Many to many Relations and conditional joins
  • September 18, 2019
  • 58 views
I am trying to build a transformation process in TX based on the following SQL code.
SELECT distinct
[BusinessEntityID]
,B.MonthKey
,[StartDate]
,[EndDate]
,[DepartmentName]
FROM [TX_DSA].[dbo].[EmployeeDepartmentHistory] A
join dbo.Calendar B ON B.Date >= A.StartDate
where b.DateValue >= a.StartDate AND (a.EndDate is null or a.EndDate <= b.DateValue)
I want intentionally to expand the grain of table A. I tried different Joins and conditional lookups but I just can't reproduce the output.
How would you solve this?
Thanks in advance
gr
Jose
Hi José
Have you read my guide regarding this?
https://legacysupport.timextender.com/hc/en-us/articles/115005972746-Improve-execution-times-by-splitting-exchange-rates-out-on-dates
Anyway I have done the same for that exact table based on experience I got from that guide.
First I have this stored procedure
CREATE PROCEDURE [DSA].[spPayRates]
@iBEntity int = NULL,
@iMaxBEntity int = NULL
AS
BEGIN
CREATE TABLE #TempTable
[BusinessEntityID] int,
[RateChangeDate] datetime,
[RateChangeDateEnd] datetime,
[Rate] decimal(38,4),
[PayFrequency] int
WHILE(@iBEntity <= @iMaxBEntity)
BEGIN
INSERT INTO #TempTable
[BusinessEntityID],
[RateChangeDate],
[RateChangeDateEnd],
[Rate],
[PayFrequency]
SELECT [BusinessEntityID],
[RateChangeDate],
ISNULL(LEAD([RateChangeDate]) OVER (ORDER BY [BusinessEntityID]),(SELECT MAX([DateValue]) FROM [DSA].[Date])) AS [RateChangeDateEnd],
[Rate],
[PayFrequency]
FROM [HR].[EmployeePayHistory]
WHERE [BusinessEntityID] = @iBEntity
SET @iBEntity = @iBEntity + 1
END
SELECT * FROM #TempTable
DROP TABLE #TempTable
END
Secondly I have a Custom Table Insert in a table.
DECLARE @1 as INT = (SELECT MIN([BusinessEntityID]) FROM [HR].[EmployeePayHistory])
DECLARE @2 as INT = (SELECT MAX([BusinessEntityID]) FROM [HR].[EmployeePayHistory])
DECLARE @Temp TABLE
[PayFrequency] int
INSERT @Temp EXEC [DSA].[spPayRates]
@iBEntity = @1,
@iMaxBEntity = @2
[DateValue] AS [Date],
CASE WHEN [PayFrequency] = 1 THEN [Rate]/30.4375 ELSE [Rate]/14 END AS [Rate],
[PayFrequency]
FROM @Temp
LEFT JOIN [DSA].[Date] AS D ON [RateChangeDate] <= D.[DateValue] AND [RateChangeDateEnd] > D.[DateValue]
This 2 part script is based on the fact that you don't always gets a straight array of dates and if I did not do this it would mix them up.
andri
  • 39 replies
  • September 19, 2019
Hi Jose
When you need to expand the grain of a table it's usually best to implement it as a custom view in the DSA and map the fields from there to the DW.
Best regards,
Andri Heidberg
  • 1172 replies
  • September 20, 2019
Hi José
AS
BEGIN
[PayFrequency] int
BEGIN
[BusinessEntityID],
[RateChangeDate],
[Rate],
[PayFrequency]
[RateChangeDate],
[Rate],
[PayFrequency]
END
END
DECLARE @Temp TABLE
[PayFrequency] int
@iBEntity = @1,
@iMaxBEntity = @2
[PayFrequency]
FROM @Temp
Thank you Thomas and Andri!
