Object reference not set to an instance of an object.
  • October 29, 2024
  • 65 views
Hi!
Getting this error when I try to open the Dev instance. Test and Prod is OK.
I could open an earlier version of the project but after I made some changes and tried to save and deploy, I first got a warning that said that this was not the latest version. When I chose to save anyway, I got the same error. Is there some way to “force save” to make this earlier version the latest one and get rid of the error?
Hi @thzman
I made an support ticket for this.
In general you should always send an email with your issue to support@timextender.com when you get object reference not set to an instance of an object errors.
  • 1129 replies
  • October 29, 2024
Hi @thzman
