SSMS Addon to view objets in schema folders
  • 231 replies
As you know in TX you can have a lotof data areas that in the SQL data base are schemas.
In SSMS you can group the objects in folders based on their schema using this addon:
https://github.com/nicholas-ross/SSMS-Schema-Folders
Hope this helps.
