Answer
Updated TX 6814.1 with strange behavior for incr tables in prepare (desktop)
  • November 18, 2024
  • 6 replies
  • 113 views
I updated our TX version to the newest 6814.1
I have added many tables in TimeXtender Ingest Server with incremental load.
Why do I have to change all incr. tables in "desktop app" to explicit incremental load, can't you use “Automatic” anymore?
Error msg: when executing with automatic on a table with incr setup from the datasource I get this type of error “Invalid object name 'shema.table_I'.”
Something I haven't done right...
regards,
Bjørn A.
Hi ​@bjorn ​@rvgfox ​@devin.tiemens
A fix has been released in TimeXtender Data Integration 6822.1. Please upgrade to this version
Please see following item in release notes for reference https://support.timextender.com/product-updates/timextender-data-integration-6822-1-2660
  • Fixed issue with Ingest Incrementally loaded tables that was added to a Prepare instance, which caused errors during deployment and execution.
devin.tiemens
  • November 18, 2024
Hi, I had same issue indeed, workaround for me was to turn Incremental load off and on again.
Hi ​@bjorn
The product team are working on a fix for this currently.
In the meantime, please select Incremental load instead of Automatic.
  • November 18, 2024
Hi ​@Christian Hauggaard
With that workaround I’m getting this error:
As ​@bjorn says, I need to setup explicit incremental rule.
  • November 19, 2024
And the SQL Database Clean tool, suggest all the _I objects to clean.
devin.tiemens
  • November 21, 2024
Great, thanks!
