What is the best practices using Global DataBases and Project?
ignacio
Hi team
I am beginning work with a new client, I created environments development, UAT, and Prod, and after I created Global DataBases DSA and MDW for now.
My question is, How I have managed the projects on Global DataBases? Only can I create one project when using Global DataBases or Can I create a lot?
Thanks for your help
Ignacio
Hi @ignacio ,
the Global Databases in Environment Properties are truly global and can be used with many projects. I think that mostly the Global Databases are used for a single project though, otherwise you may get conflicts.
Sharing Data Sources between projects is a bit more common.
  • August 16, 2023
Hi @ignacio ,
ignacio
  • 29 replies
  • August 16, 2023
Thanks for your response @rory.smith. it is clear.
