Field with Integer Datatype not valid in RestAPI
Hi all,
I am using a Cdata Restapi to connect to a datasource, and it has been working fine up to now.
It seems they have changed one of the fields, used for incremental loading, and this has now become too long to fit in a integer data type.
I have had contact with the support team of the datasource and it seems the field had always been setup as a int64 field (not documented very well), but the value wasn't that big in the past. Now I get errors when retrieving data , stating that the field is too small.
How can I adjust the field definition in TX so that it is a bigint field instead of int32? I tried with override datatype, but initially it still wants to load the data in int32.
Using the TX 20.10 version, with business units and a cdata restapi connection.
Has anyone experience with this?
Kind regards,
Jacqueline
Hi Thomas,
This depends on exactly where the error is being thrown, but if it is a datatype conversion error in the driver, you will likely be able to fix this by changing the column type in the RSD from an int to a long.
Can you try this suggestion. If it does not work, let me know about it.
  • 1017 replies
  • May 24, 2024
Hi @jacqueline.hofmeijer
It does not seem like you can expand the size to a bigint.
I will ask CData if we somehow are able to do this.
wouter.goslinga
@jacqueline.hofmeijer can you set it to a decimal(20,0)? Best would be to do that in the RSD file so that the entire data flow sees it as this type, including TX.
  • 1017 replies
  • June 7, 2024
Hi Thomas,
@jacqueline.hofmeijer were you able to test changing the column type in the RSD file as suggested by Thomas above?
Sorry for my late reaction, have been on a holiday.
For now I used the option to define this as a decimal field in the rsd-file and from that convert in TX to a bigint, and that is working fine.
Since this is a large database, changing it to a different format is not something I can easily do in the live environment, but I will check with a smaller dataset what the impact is on the project. When I have results I will let you know.
Kind regards, Jacqueline
Tried the option that Thomas suggested by using the datatype Long in the rsd-file. This is also working correctly by defining the datatype in TX as a int64 field.
I have been searching the entire documentation of cdata, but somehow missed this option, or maybe this is not defined very clear.
Thanks for all the support again!
