REST connection with JSONROWS - Columns and rows within same array
I am trying to parse a response using the REST connector from an API which returns a JSONROWS-format where the first row contains the name of the columns, while the following rows contain the values.
The response is on the form:
    "response":[
            {"name":"test1"},
            {"name":"test2"}
            1,
            2
            3,
            4
            5,
            6
I have tried several different xPath-configurations. The following gives the correct columns, but returns zero rows:
xPath:        column:/response;columnname:/response.name;row:/response
I was hoping that at least this would have parsed all the values as strings with the first row containing the {“name”:”testN”} in the corresponding columns.
How do I work with this response?
Hi @andreas.skagestad
I seem to have forgotten to give an update on this.
I got a new version of the provider called 23.0.8595.0 that should have resolved this issue.
  • 1100 replies
  • April 26, 2023
Hi Andreas
Did you see my guide about this.
REST and JSON can be used interchangeably, so it will work for this one too.
I could not really make it work with the file you shared. I changed it to this.
	"response":{
		"columns": [
			{"name":"test1"},
			{"name":"test2"}
		"rows": [
				1,
				2
				3,
				4
				5,
				6
As you can see I added a columns and a rows part to the file.
Then using this JSONPath and having the JSON type set to JSONRows it worked.
JSONPath: column:$.response.columns;columnname:$.response.columns.name;row:$.response.rows
Hi Thomas,
Yes, it works fine if columns and rows are put in separate arrays, but changing the response from the API is not an option here.
I guess there is no way around external scripts in this case?
  • 1100 replies
  • April 26, 2023
I thought about that too, I am not sure how to specify what is columns and what is rows, when there is nothing to point at.
The JSONPath would have to be like this. column:$.response;columnname:$.response.name;row:$.response
I can’t see how it would know where the data is, when no field specifies it.
I can ask CData if they know of some workaround to make it work?
  • 1100 replies
  • May 3, 2023
Hi Anders
I have asked CData for help with this. I will let you know if they know a way to do this.
  • 1100 replies
  • October 17, 2023
Hi @andreas.skagestad have you tried with the latest version of the provider? Please let us know if this resolves your issue
