Setting up post curl in "script action"
  • May 11, 2023
  • 110 views
Hi TimeXtender
I have an urgent request (!)
I am trying to set up a Script action (which I will later use in a table as a post-script) that executes a POST CURL in a different tool.
I have tried to execute the POST CURL in Postman and it is working.
Now I want to do the same from TimeXtender.
I have an URL and a Token.
How can I set it up?
Looking forward to hearing from you.
Ismail
Hi Ismail
Are there any other programs that can run this curl, I seem to remember that the command prompt could do this.
Or perhaps a Powershell script. It seems like it is possible after a short Google.
If you are using version 6xxx.1 you have an option of adding this as an External Executable.
If you use an earlier version you will need to create a job on an SQL server which you can run from a script action. The SQL job can then run the command curl or the Powershell script.
  • 1091 replies
  • May 11, 2023
Hi Ismail
