Answer
Pagination using "hasMore" response
  • August 26, 2024
  • 9 replies
  • 219 views
I am dealing with an API that let’s me query its database. With LIMIT and OFFSET I want to fetch all the rows dynamically using an RSD file.
Here’s the json response:
"entities": [
"Portfolio": {
"id": "9999999999999999",
"Name": "Test9"
"Portfolio": {
"id": "1111111111111111",
"Name": "Test1"
"paging": {
"from": 2,
"hasMore": true,
"limit": 2
And here is my RSD file. I haven’t gotten it to work with pagination and I just get the error
The attribute 'hasMore' does not exist.
<api:script xmlns:api="http://apiscript.com/ns?v1" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<api:info title="entities" desc="Generated schema file_" xmlns:other="http://apiscript_com/ns?v1"> />
<attr name="portfolio_id" xs:type="string" readonly="false" other:xPath="/json/entities/Portfolio/id" />
<attr name="portfolio_name" xs:type="string" readonly="false" other:xPath="/json/entities/Portfolio/Name" />
<input name="rows@next" default="0" />
</api:info>
<api:set attr="DataModel" value="FLATTENEDDOCUMENTS" />
<api:set attr="BASEURI" value="https://apie1.clarizen.com/V2.0/services/data/query" />
<api:set attr="ElementMapPath#" value="/json/paging/hasMore" />
<api:set attr="ElementMapName#" value="hasMore" />
<api:set attr="EnablePaging" value="TRUE" />
<api:script method="GET">
<api:set attr="AddToURI" value="q=SELECT+Portfolio.Name+FROM+Portfolio+LIMIT+2+OFFSET+[_input.rows@next]"/>
<api:set attr="URI" value="[BaseURI]?[AddToURI]" />
<api:set attr="method" value="GET"/>
<api:call op="jsonproviderGet">
<api:if attr="hasMore" value="true" operator="equals">
<api:set attr="rows@next" value="[rows@next | Add(2)]" />
</api:if>
<api:push/>
</api:call>
</api:script>
</api:script>
If I’d script this in Python I’d just have a while hasMore=’true’ THEN continue. But I’m unsure how to do this with an RSD file.
Best answer by Gardar
@Thomas Lind, thanks for the suggestions! It worked with the following:
<api:set attr="JSONPath" value="$.entities;$." />
I thought that by setting JSONPath to “.$” it would include all subcategories as well. If I set it to only “$.entities” it would not find the hasMore attribute. Setting it to the above returns all rows as they should be.
  • August 28, 2024
Hi @Gardar
If you hit the last page where the hasMore is False, what is the pagination result looking like?
Also do you have the Row Scan Depth set to 0?
  • August 29, 2024
Hi @Thomas Lind,
The pagination when using LIMIT 2 OFFSET 1615 reaches the end of the list with this pagination result:
"paging": {
"from": 1616,
"limit": 2,
"hasMore": false
I did not have row scan depth set to 0 as the query should only return 2 rows (+ paging result). I now tried to set it to 0 but I get the same error:
  • August 29, 2024
I may be missing something obvious but is the element mapping really necessary? For basic pagination it should be enough to just add the hasMore field like this:
<attr name="hasMore" xs:type="xs:boolean" readonly="false" other:xPath="/json/paging/hasMore" />
And you may need this:
<api:set attr="Repeatelement" value="/json/entities" />
Can you verify that you are actually getting one page with a result (I expected some kind of authentication first).
  • August 29, 2024
@RLB Thank you for the answer. The problem I have is that I need to pass in a LIMIT and OFFSET into the API request. I assume that this type of “Repeatelement” approach would work under normal circumstances. If I do as you have said, I will only get 2 rows as the attribute [AddToURI] is not changing.
  • August 29, 2024
Hi @Gardar
Try this setup.
</api:info>
<api:set attr="JSONPath" value="$.entities.Portfolio" />
</api:if>
<api:push/>
</api:call>
</api:script>
</api:script>
What I did was to add a JSONPAth field to point at the data. This may be part of the issue, also consider changing the DataModel to just DOCUMENTS.
  • August 29, 2024
Thanks @Thomas Lind. I tried your suggestion but the error stayed the same. I changed the JSONPath to:
<api:set attr="JSONPath" value="$." />
And it seems to work “somewhat” now. I changed it to LIMIT 1000 and
[rows@next | Add(1000)]
As there are >1600 rows to fetch, I see in the log_file (with verbosity = 5) that it is doing the correct thing:
GET https://apie1.clarizen.com/V2.0/services/data/query?q=SELECT+Portfolio.Name+FROM+Portfolio+LIMIT+1000+OFFSET+0
followed by:
GET https://apie1.clarizen.com/V2.0/services/data/query?q=SELECT+Portfolio.Name+FROM+Portfolio+LIMIT+1000+OFFSET+1000
And I see in the buffer log that it is fetching all the data.
But it seems that it only returns the first row of each query. Selecting from the portfolio table in TimeXtender returns only 2 rows.
  • August 29, 2024
Hi @Gardar
It likely still is the JSONPath that is the issue.
$. is the highest level it may not return more than one row. See if you can try other options like $.entities and similar
  • August 29, 2024
  • August 30, 2024
Hi @Gardar
When you use FlattenedDocuments as the DataModel adding multiple options in the JSONPath field is normally what is expected. So using ; between statements pulls all together in one file.
