SAP Connection without Theobald Connector
  • September 13, 2024
  • 53 views
We have a Midmarket customer in India who want to use TimeXtender for Analytics Purpose, but not keen to invest in Theobald. What is the most effective and reliable way to connect to SAP to extract Data to TimeXtender. Also if you can share step-by-step guide with example.
@pkaustubha which SAP instance does the customer have? e.g. HANA, BusinessOne, etc
As mentioned in the below post, it might be possible to extract via OData API using TimeXrender REST data source connection if it is SAP BusinessOne
@pkaustubha could you please provide an update on the above?
  • 17 replies
  • September 20, 2024
I am yet to try on Business One on HANA, but have been able to connect with SAP HANA Database using CData Connector.
