SAP Public Cloud - TimeXtender Connection
  • August 28, 2024
  • 46 views
We have a prospective customer in India who is using SAP Public Cloud. Would like to know how can we connect SAP Public Cloud to TimeXtender. Need your inputs on the same as we need to start a PoC with them in this week.
Have anyone tried and connected. If yes please share your experience.
use JSON connector with Theobald Xtract Universal:
https://helpcenter.theobald-software.com/xtract-universal/knowledge-base/supported-sap-and-hana-versions/
Take note of the limitations for SAP Public Cloud. I believe Xtract IS does not support the websocket connectivity required.
  • 649 replies
  • August 28, 2024
