Could not connect to the database via Data Enrichment
In this article, you will find a possible solution if you could not connect to the database via Data Enrichment.
This issue can be caused by a few reasons:
  • Port 1433 is closed on the local network
  • The machine is on a network blocked by the Azure firewall
