ExMonDM Actions give you a simple way to store frequently used scripts or procedures relevant to the table. These scripts can then be executed by anyone editing the table data. Commonly used Actions are row validations, browser shortcuts and pushing data from exMonDM to other systems.
Note: Actions can contain parameter values, which allows the user to input values when the action is about to run.
When an action with parameters is run on the web, a small box appears where you can insert the parameter values. When all the values have been entered you can run the action.
