TimeXtender Orchestration, Data Quality and Data Enrichment IP addresses
  • April 8, 2024
  • 566 views
Note: allow access for *.exmon.com and *.exmondm.com on Port 443 when using DNS.
These are the IP addresses for mp77op1ebc.database.windows.net that require opening the firewall against:
  1. 104.40.169.32/29
  2. 13.69.112.168/29
  3. 52.236.184.32/29
  4. 20.61.99.192/27
For sql-exmon-prod-001.database.windows.net these are the addresses:
  1. 104.40.169.32
  2. 13.69.112.168
  3. 52.236.184.32
  4. 20.61.99.192
  5. 20.61.99.193
  6. 20.61.99.197
  7. 20.61.99.194
For login.exmon.com and other TimeXtender application webs, these IP addresses must be opened:
List:
  1. 18.66.165.49
  2. 20.50.2.33
  3. 20.60.250.196
  4. 20.73.113.133
  5. 20.73.113.175
  6. 20.73.113.192
  7. 20.73.113.199
  8. 20.73.114.46
  9. 20.73.114.80
  10. 104.19.153.19
  11. 104.19.152.19
For Auth0 which is used for Authentication:
  1. 18.197.9.11
  2. 18.198.229.148
  3. 3.125.185.137
  4. 3.65.249.224
  5. 3.67.233.131
  6. 3.68.125.137
  7. 3.72.27.152
  8. 3.74.90.247
  9. 34.246.118.27
  10. 35.157.198.116
  11. 35.157.221.52
  12. 52.17.111.199
  13. 52.19.3.147
  14. 52.208.95.174
  15. 52.210.121.45
  16. 52.210.122.50
  17. 52.28.184.187
  18. 52.30.153.34
  19. 52.57.230.214
  20. 54.228.204.106
  21. 54.228.86.224
  22. 54.73.137.216
  23. 54.75.208.179
  24. 54.76.184.103
Data Enrichment:
  1. 20.61.99.192
  2. 20.166.40.71
Preferably all of these should be opened to ensure that in the future you will not need to open other IP addresses:
List:
  1. 20.73.233.133
  2. 20.73.233.186
  3. 20.73.238.52
  4. 20.73.239.10
  5. 20.73.239.153
  6. 20.73.239.154
  7. 20.73.239.160
  8. 20.73.112.106
  9. 20.73.112.111
  10. 20.73.112.143
  11. 20.73.112.153
  12. 20.73.113.60
  13. 20.73.113.133
  14. 20.73.113.175
  15. 20.73.113.192
  16. 20.73.113.199
  17. 20.73.114.46
  18. 20.73.114.80
  19. 20.73.114.83
  20. 20.73.114.88
  21. 20.73.114.105
  22. 20.73.114.165
  23. 20.73.114.206
  24. 20.73.237.142
  25. 20.73.115.12
  26. 20.71.75.226
  27. 20.73.115.29
  28. 20.73.115.77
  29. 20.73.115.118
  30. 20.73.115.135
  31. 20.50.2.33
CodeFormat:
20.73.233.133,20.73.233.186,20.73.238.52,20.73.239.10,20.73.239.153,20.73.239.154,20.73.239.160,20.73.112.106,20.73.112.111,20.73.112.143,20.73.112.153,20.73.113.60,20.73.113.133,20.73.113.175,20.73.113.192,20.73.113.199,20.73.114.46,20.73.114.80,20.73.114.83,20.73.114.88,20.73.114.105,20.73.114.165,20.73.114.206,20.73.237.142,20.73.115.12,20.71.75.226,20.73.115.29,20.73.115.77,20.73.115.118,20.73.115.135,20.50.2.33
For DNS format you can rather open for these URLs on port 443:
  1. *.exmon.com
  2. *.exmondm.com
bas.hopstaken
@Christian Hauggaard : It would be great if the above list could be subdivided into the individual products: Orchestration, Data Quality, and Data Enrichment. Not all customers purchase all products all the time and therefore don't want to open all ports in the firewall.
