In this article, we will query to ensure all TimeXtender Orchestration & Data Quality users are enabled in Active Directory. You can utilise TimeXtender Orchestration & Data Quality to ensure all your users are active users in your corporate Active Directory.
Add Active Directory PowerShell support
To query Active Directory with PowerShell you will need to add the necessary support. Here you can find out how to configure it.
Configure the test
- Create a new Compare Query in TimeXtender Orchestration & Data Quality by right-clicking the Tests folder
- In the left query select the PowerShell Data Provider and add the following PowerShell script:
import-module activedirectory
$exMonResult = Get-ADUser -Filter {Enabled -eq $false} | exMon-Out-DataTable - In the right query select Data Provider and add the following PowerShell script:
declare @domain varchar(20)
set @domain = 'EXPECTUS'
select distinct
substring(ad_name, len(@domain)+2, len(ad_name)) as ad_username
from dbo.c_user - Replace 'EXPECTUS' with your domain name
- In this query, we want to find all disabled users in your active directory. To do this, ensure that DS2 incl. DS1 is selected but DS1 incl. DS2 is deselected.
- Create a column mapping where the usernames are the keys and the name is an information column so it's easier to recognize the user.
- Configure exception manager and schedule as usual.
Running the Preview will show you the results:
