TimeXtender Orchestration and Data Quality Integration Actions
  • April 3, 2024
  • January 3, 2025 at 11:04 AM
  • 317 views
In this article, you will read about the TimeXtender Orchestration and Data Quality Integration Actions. Integration Action allows TimeXtender Master Data Management to execute TimeXtender Orchestration and Data Quality tasks. This can be done through the context menu, toolbar button or when the table is saved.
Worked Example
  1. Open TimeXtender Master Data Management
  2. Open an existing project or create a new demo
  3. If creating a new project, name it Integration_Action_Demo
  4. Then, click create table and name it Integration_Action_Demo_Table
  5. Make sure that the Project selected is the Integration_Action_Demo project you just made
  6. Click Save
  7. At the top of the page, click Table Designer
  8. Now click Actions...
  9. In the bottom left of the modal, select the Add dropdown
  10. Select Execute in TimeXtender Orchestrator
  11. Create a new connection
    1. Name your connection Integration_Demo
    2. Ensure the connection type is an SQLserver
    3. Add in your hostname & initial catalogue
    4. Fill out the authentication credentials
    5. Click Generate Connection String
    6. Click Test Connection
    7. On connected, click Save
  12. Write Integration_Sample on Display Name and DB Name
  13. Select the desired connection (usually your corresponding TimeXtender Orchestration and Data Quality)
  14. Select the desired system within TimeXtender Orchestration and Data Quality
  15. Select the desired task to execute
  16. Optional - configure additional properties which are the same as for other actions
  17. Run the task and make sure everything runs successfully
  18. Click Save
