Troubleshooting Errors When Running a PowerShell Package via Gateway
  • August 29, 2024
  • 50 views
Dagný Björk Stefánsdóttir
This article provides guidance on how to resolve common errors that may occur when running a PowerShell package through Gateway.
Issues and Solutions
If you encounter the following error message, it indicates that the user executing the script does not have access to the Az library:
Register-AzModule : The term 'Register-AzModule' is not recognized as the name
of a cmdlet, function, script file, or operable program. Check the spelling of
the name, or if a path was included, verify that the path is correct and try
again.
To resolve this issue, check the following:
  1. User Access: Ensure that the user running the Gateway service has the necessary access to the Az library folder.
  2. Disk Space: Verify that the server hosting the Gateway service has sufficient disk space available.
  3. RAM Availability: Confirm that the server running the Gateway service has adequate RAM to execute the script without running into memory issues.
