Error: "Error while copying content to a stream" for SQL data source transfer task
Symptoms:
Error during transfer task while ingesting data from a SQL server data source to an Ingest instance with Azure Data Lake storage. The error message typically includes:
Error: System.Net.Http.HttpRequestException: Error while copying content to a stream.
Cause:
The issue is likely related to concurrency settings and resource limitations.
Resolution:
  1. Increase Timeout Settings:
  • Increase the timeouts for the Data Lake Ingest Instance in the TDI portal.
  • Ensure the timeout is set to a value that accommodates the data transfer size.
  1. Reduce Concurrent Execution Threads:
  • Lower the number of concurrent execution threads to e.g. 2.
  • This can be done in the Ingest Instance data source advanced settings.
  1. Monitor and Adjust Resource Allocation:
  • If reducing the threads resolves the issue, consider scaling up the VM running the Ingest Instance Server to handle more concurrent tasks.
  • Monitor the performance and adjust CPU and memory allocation as needed.
Reference Ticket:
34258
Reference Links:
