Cloud users can run PowerShell scripts without using an execution connection. However, they are limited to commands that the TimeXtender team has whitelisted.
If the allowed commands are not enough, you can use TimeXtender Gateway to create an execution connection. Running PowerShell through an execution connection gives you full control of what commands you can run.
The following commands are currently available:
- Out-Default
- Invoke-WebRequest
- Get-Date
- Invoke-RestMethod
- New-Object
- ConvertFrom-Json
- ConvertTo-Json
- Write-Warning
- Write-Output
- Select-Object
- Start-Sleep
- Get-Random
- Where-Object
