Issue using multiple BC adapters at the same time.
We are currently experiencing a problem with using multiple BC  (NAV) Adapters at the same time. The two connectors are set up with individual app registrations as one is in the same Azure Tenant as where we are kicking off the execution, and one is in a different tenant all together.
When I execute these tables one at a time or one source at a time, it runs smoothly with no issues. The issue is trying to run both sources at the same time. When I try that, it gives the following error:
The connectors are set up correctly as I am able to run them seperately.
Does anyone have a fix or workaround for this issue?
For the record: we are on Version 20.10.44.64 and we are using Business Units.
Hi ​@MvHolland
Can you try to run the setup without a translation in the BC 365 Provider setup.
Just click Load values and then unselect any translations.
See if it still gives the same error then.
  • 713 replies
  • March 26, 2025
you might be able to get some clues as to what is going wrong from Entra logging (either general or from the app reg's specific logs). It may be that running separately authenticates against the separate tenants but running at the same time tries to authenticate via one tenant.
  • 1100 replies
  • March 26, 2025
Hi ​@MvHolland
Are you using the additional data sources option to do this?
Are you using Service to Service authentication?
  • March 27, 2025
I am unable to check the logging in the App reg, as i do not have the authorization for that. I'll try to get the logs but that might take a while.
@Thomas Lind  we are using Service to Service authentication for both, yes. The way i have it configured is that i have 2 separate connectors in 2 separate BU's, using the business central (NAV) connector without any additional settings, except for a language enhancement. Unsure what other settings we could try for this.
  • 1100 replies
  • April 2, 2025
Hi ​@MvHolland
The language part may be the issue.
Can you show how it is set currently?
  • April 4, 2025
Hi ​@Thomas Lind ,
both the connectors are set up in the following way:
Additionally, we have the display settings set to nl-NL,
  • 1100 replies
  • April 4, 2025
Hi ​@MvHolland
@MvHolland did you get a chance to try Thomas’ suggestion above?
  • May 6, 2025
Sorry, i was on vacation for the past 4 weeks so was unable to try the above solution. That does indeed work!
Thanks!
