Load automatic process CVS Files
ignacio
Hi community,
I have to design the following issue, every day, I have a new CVS file in the Azure storage account. These file’s name change with a new day, for example
FormaExtract.net_new_commission_2023-03-01.csv
FormaExtract.net_new_commission_2023-03-02.csv
FormaExtract.net_new_commission_2023-03-03.csv
How I could create an automatic process to load a new file to the table in DSA? Now I will do it manually
adding every day a new file an process the data.
ODX
DSA
Another requirement is to create a new column SourceMainTable in the DSA table with the file’s name.
Regards
Ignacio
Best answer by bas.hopstaken
Hi @ignacio ,
You can use the aggregate files option if you are using the CData CSV connector. If you use this connector, combined with the aggregate files option. A column is added that contains the source file name as well.
It is explaned in this article:
https://support.timextender.com/data-sources-112/connect-to-csv-data-sources-732#Aggregate+multiple+files+into+one
bas.hopstaken
  • 90 replies
  • March 22, 2023
Hi @ignacio ,
ignacio
  • 29 replies
  • March 23, 2023
Thanks, Bas! I Could design the solution!! 😁
