TimeXtender REST dynamic values - error on Sync
  • October 9, 2024
  • 56 views
Hi!
I’m doing some tests and trying to set up som e form of incremental load with this connector to an API endpoint. It works fine with the two static parameters but as soon as I add the parameter for lastSynchronizedRowVersion with its dynamic value I get an error with I run the Synchronize job.
Is there something obvious that I have missed here?
I tried to follow the article Connect to Fixer IO with the TimeXtender REST data source | Community
Setup for the endpoint:
Error message:
Best answer by nmo
In the “Connection string” field, have you just written the server name, or have you prefixed it with “server=”?
I have just struggled with the same error, and mine was caused by forgetting to prefix with “server=”
  • 25 replies
  • October 9, 2024
  • 24 replies
  • October 9, 2024
Yes. You are totally correct. I had omitted that part. Thanks for pointing it out. :)
