Exmon 23.1
Related products:Exmon
We are excited to bring you the Exmon 23.1 release with new features and improvements.
Summary
We are excited to bring you the first version of 2023. In this release, we bring improved hierarchies with added features in the DM web application. In Exmon DG, users can now select default email templates globally, per system, and, per query.
Exmon Data Management
Hierarchies in web
We have continued to work on the hierarchies in the web application. New features that are included in this second version of the preview are: adding children to nodes, unassigning nodes, and improving the experience when moving nodes. Additionally, we have made some smaller improvements and bug fixes. Read more about the web hierarchies this article.
Execution queue change for DM’s DG action
The Execution Queue has been added to on premise DG actions. With this change on premise Exmon users no longer require direct access to the server that should run the task but instead the execution connection polls Exmon DG for tasks to execute. This change prevents issues such as execution connection overload and firewall problems. Read more about DG actions here.
Exmon Data Governance
Set email template as default template
The ability to set an email template as default for the entire environment or per system has been added to DG. At the report level, if no template is specifically chosen for the report the system level default will be used. If no system level default is set the global default will be used instead. At the system and report level, the current default will be indicated in the dropdown list of templates.
Switch from DG portal to other products
If your account is associated with multiple Exmon services. You can now switch between them from the DG portal by clicking the service name in the top right corner.
Bug fixes and smaller improvements
Data Governance
  • Command line packages could not be opened from Execution History
  • Status page on DG portal cloud could not be opened
  • Error when selecting Data Provider in Source in Data transfer package
  • Saved Comparative did not always work correctly
  • Compare queries using DateTime column as value did not work
  • TX packages ended unsuccessfully when TX had multiple projects
  • DM Data provider does not show up in Data provider command packages
  • UI for Data Provider type Data Management is incorrect
  • Incorrect data was shown in Available Data Providers column when creating Data Provider Group
  • Data Providers were sometimes visible in incorrect Systems
  • Data Provider Groups are displayed twice in the navigation
  • Sometimes queries could not be opened
  • Switching from PROD to Development did not work in the web client for cloud users
  • Some users could not create new queries
  • Some tasks failed when being run in a Schedule
  • Cache did not refresh when a user created a new system
  • It was not possible to save Power BI Refresh package without a subscription
  • Power BI Refresh package did not work correctly
Data Management
  • Desktop:
    • Import into double column did not work
    • Run Task button disabled when DG Action was opened in the Table Designer
  • Web application:
    • Could not open hierarchies with decimal columns
    • Default values did not work when adding a row to a table
    • Users without table administrator privileges were not able to change column order in hierarchies
    • Previously assigned nodes were shown at the top of the Hierarchy instead of in the Unassigned section in hierarchies
    • Clicking the Exmon logo to go to the start page in hierarchies did not work
    • The color of read-only columns in tables was wrong
    • When a child node was added in a hierarchy, the parent node was collapsed, and it looked like the child node had not been added
    • It was not possible to search for hierarchies in the navigation
    • The UI was stuck loading after user clicked “continue without saving” when importing into a table in the web application
    • Running DG Action did not always work
Turnkey
In this version of Turnkey, we have emphasized improving the user interface and user experience.
If you are interested in becoming a beta tester for Turnkey, please contact us at support@exmon.com
New UI for Dataset Column Settings
New UI for Rule Column Settings
How to upgrade?
In Exmon Data Management, users in versions 22.5 and above can complete the upgrade themselves through the Desktop client. See the Guide.
Contact support@exmon.com to upgrade
