TimeXtender Desktop 6430.1
Related products:TimeXtender Data Integration
Thomas Hjermitslev
Today, we’ve published a minor release of TimeXtender Desktop (v. 6430.1) that contains the following changes:
Changed
  • Removed the ‘Copy to Instance’ feature from Desktop as this is now done in the Portal.
Fixed
  • Executing an execution package with an incrementally loaded table added to the Full Load objects list would do a wrong cast and throw an error.
wouter.goslinga
That is a really quick fix guys :)
  • October 25, 2023
@Thomas Hjermitslev Is it neccessary upgrade the execution service too or only the desktop?
Bitmetric_Maarten
I've informed support as well, but we noticed that in deploys it deploys the guarded tables and not the normal tables, instead of vice-versa.
  • October 25, 2023
@Thomas Hjermitslev Eith this version I’ve detected problems when I deploy a data area with the option:
I get an error message saying that the data base doesn’t exists ¿?
  • October 26, 2023
Hi @rvgfox
Yes. The execution service is part of the TimeXtender program so it you should use the one for this release. The ODX is not updated, so you can keep that.
Please add a support ticket with this issue, specifically what steps you went through to get the error and the error message details.
