SSAS Perspectives
  • April 6, 2023
  • September 16, 2024 at 12:44 PM
  • 1361 views
Note: Perspectives apply to Tabular endpoints only.
Tabular models can become complex with numerous tables, fields, and measures, making it challenging for users of analysis and visualization tools to maintain an overview and quickly locate specific objects they need. To address this, SSAS Perspectives are introduced as a subset of objects within a tabular model that users of tools like Power BI, Excel, and others can apply to simplify their interaction with the model.
A SSAS perspective represents a focused subset of objects in a tabular model that relates to a specific area. For instance, you can create a "finance" SSAS perspective that includes all objects related to finance. When this perspective is utilized in front-end tools, any objects outside this subset will be hidden, providing a streamlined view for users.
Add or Edit a Perspective
Expand the instance, and right-click on Deliver instance model. Select Manage Perspectives.
Click on Add in the Perspectives window to create a new perspective.
Rename a Perspective
Double-click the Perspective header to rename it, e.g., "Finance Model".
Adding Objects to a Perspective
Select the checkboxes for the objects you want to include in the perspective.
Note that when all objects in a table are selected, the table is marked with a checkmark. If only some objects are selected, the table is marked with a dot.
Click OK after selecting the objects.
Deploy and execute the Deliver instance for the SSAS perspective to take effect.
Using the SSAS Perspective in a Front-End Visualization Tool
Power BI
Select Get Data > From Analysis Services
Enter the server name and credentials, then select the SSAS database and perspective. Click OK.
Excel
Enter the server name and credentials, then select the SSAS database and perspective. Click Finish.
SSMS
Browse the SSAS database in SSMS
Click the three dots next to the SSAS database in the Browse tab, select the SSAS Perspective, and click OK.
Troubleshooting
Error: No data fields are available in the OLAP cube
To resolve this error, ensure that a measure is selected in the SSAS perspective.
  • September 22, 2023
This only works if you have standard edition of Azure analysis services as mentioned in this thread No perspectives when deploying tabular model | Community (timextender.com). Or if you are running it locally on a sql server instance, then you need the enterprise edition of sql server, since perspectives only work then with developer or enterprise edition. We also discussed this already with @Thomas Lind, about possibly workarounds for users with only standard edition. This could possibly be added in the article or later in the thread when found.
P.S.
If you try to create perspectives in the GUI, with a local standard edition sql server, it will deploy without problems. Maybe a warning should be put in place here to indicate that it cannot create the perspectives due to environment constraints.
