Connecting to Data Sources in TimeXtender Classic
  • August 15, 2025
  • 115 views
Data sources contain the data that you want to load into your data warehouse and use for analysis. TimeXtender supports two different approaches for connecting to source systems: simple data sources and intelligent application adapters.
Data source guides
A data source connector simply connects to the source and enables you to browse the content of the source. The current version of TimeXtender connects to the following data sources:
In addition to that, TimeXtender can connect to other data sources using one of the following approaches:
An adapter is a component that enables you to easily extract and synchronize data from different source systems. The adapter knows how a given system organizes and stores data, which enables the adapter to simplify the table structure you see in TimeXtender.
For instance, data for each company in a Dynamics Business Central (NAV) system is stored in a separate set of tables. The Dynamics Business Central (NAV) adapter merges these tables and lets you select companies on a global level.
TimeXtender includes Application Adapters for the following systems:
Data Extraction
Once you have added and configured a data source, the next step is to select the tables and fields you want to copy into the staging database. For more information, see Moving Data from a Data Source to a Staging Database.
Selection templates offer another way of selecting what data to copy into the staging database. For more information, see Selection Templates.
This section covers the settings for data extraction associated with data sources in general.
Integration services
On most data sources, you will find the setting Use Integration Services For Transfer that determines how TimeXtender transfers data between a source and a destination table. You have the following options:
  • As Parent: The setting will be taken from the project setting 'Use Integration Services'.
  • Yes: A SQL Server Integration Services (SSIS) package is used. This requires that the SQL Server component Integration Services is installed on the machine that deploys and executes the tables.
  • No: ADO .NET is used. This does not require any SQL components except SQL Server Management Objects.
Using SSIS packages for transferring data is generally considered to be faster for transferring large amounts of data. When transferring data between tables with fewer records, using ADO .NET can sometimes be faster, as it takes time to load the SSIS packages from the SQL Server where they are stored before data transfer can begin.
It takes significantly longer to deploy SSIS packages than it does to deploy ADO .NET transfer. This setting can have a great impact on the overall deployment time of a project.
SSIS and ADO .NET use different technologies to transfer data. This means that if you get erroneous data through SSIS, you can sometimes get correct data using ADO .NET.
Simple Mode
Simple mode is a setting aimed at maximizing performance when you need to copy large amounts of data to create an exact copy. When a table is in simple mode, everything but the most basic functionality is disabled:
  • Tables in simple mode do not support field transformations, field validations, conditional lookup fields.
  • Tables in simple mode only have the valid instance of the table unless incremental load is enabled.
Per default, a data source inherits the simple model setting from the business unit, but you can override the setting on the data source and on individual tables on the data source.
To enable simple mode for a data source
  • Right click the data source, click Data Source Settings and click Enable under Simple mode.
Guarding a Data Source
You can guard a data source in TimeXtender, which prevents tables that get their data from the data source from being deployed, executed or both. In general, the guard feature is useful for tables that contain data that never changes, e.g. from a legacy system. You can also guard a single table. See Guarding a Table for more information.
To guard a data source
  • Right click the data source and click Data Source Settings. Select Guard on deployment to prevent TimeXtender from deploying the table and/or Guard on execution to prevent TimeXtender from executing the table.
Limiting Concurrent Transfers on Data Source
You can put a limit on the number of concurrent transfers from a specific data source. Some data sources can only handle a certain number of transfers before adding more transfers will actually slow down the overall performance of the transfer rather than speed it up.
To limit the amount of concurrent transfers from a data source
  • Right click the data source, click Data Source Settings and enter the allowed number in the Max concurrent transfers box. "0" equals unlimited.
Allowing a Data Source to Fail
If you have some source systems in your solution that are less than critical for your reporting, you can configure your solution so that the entire execution does not stop just because TimeXtender cannot reach these noncritical systems. Instead, you can choose to keep the newest data from the system in question until fresh data can be fetched.
Follow the steps below to allow a data source to fail.
  1. Right click the data source and click Data Source Settings.
  2. Under When transfer fails, click the option you want to use if the transfer should fail. You have the following options:
    • Fail and stop the execution: Stops execution and reports the execution as failed (default setting).
    • Continue execution without data: Continues the execution, pretending that the source contains no data.
    • Continue with existing data: Continues execution, retaining the existing data from the source.
Note: If you use additional connectors, you need to configure this setting on the additional data source as well as the template data source.
If a data source, that you have allowed to fail, fails during execution, the following execution message will be recorded: “Execution was successful, but one or more data sources failed".
Filtering What Objects to Extract
For large data sources, the amount of tables and fields can make it hard to maintain an overview when you select what data you want to use in your project. To enable you to limit the number of objects brought into your project before the data selection stage, TimeXtender contains a data extraction filter.
The data extraction filter is available on most data sources. To apply a data extraction filter, follow the steps below.
  1. Right click the relevant data source, click Edit [data source] and click Data Extraction Settings
  2. Under the Objects to extract option, clear the checkboxes next to the object types you do not want to extract.
  3. Under Object filtering, click Add to add a rule that tables and views must pass to be included in the extraction. For instance, a "like: sales" rule in the schema column means that only tables and views in the "sales" schema will be included.
  4. Click OK to close the window and click OK in the Edit [data source] window to save the filter.
  5. Right-click the data source and click Synchronize Data Source to apply the filter.
Disabling the Column Cache
When you select data for extraction from a source, you can filter, sort, and group the available tables and columns to find the exact objects you are looking for.
With large data sources, loading the metadata for this can be time and memory-consuming. TimeXtender contains an option to toggle the caching of columns to cut the number of objects that are loaded and cached down to a manageable size. The downside is that you can then only filter on table names, not column names.
To disable the column cache
  • Right-click on the source, click Data Source Settings, and clear Enable full column caching under Data Extraction.
Note: This option is not available on Dynamics Business Central (NAV) and Dynamics AX adapters and text file data sources.
Data Type Overrides
You can override the data type of fields on the data source level. While you can choose the data type for each individual field in the data warehouse, it is easier to do so on the data source level if you use the same field more than once in the data warehouse.
Data type overrides are implemented as rules that can be added and ordered to create a hierarchy. For each field, TimeXtender goes through the rules and applies the first rule that matches if there is any that does.
Under the data source in the tree, a field's original data type is displayed, while the overridden data type is displayed anywhere else.
Adding a Data Type Override to a single Field
To add a data type override to a single field on a data source, follow the steps below.
  1. Right-click the field and click Override Data Type. In the Converts to list, click on the data type you want to use and then adjust any settings for the data type you have selected.
  2. Click OK.
  3. Right-click on the data source and click Synchronize Data Source to apply the overrides.
Note: This creates a rule that matches the schema, table and field name of the field. If one of these names change, the rule will no longer match.
Adding a Data Type Override Rule
If you want to add a data type override that matches more than a single field, follow the steps below.
  1. Right-click a data source, click Data Source Settings, and click the Data type override tab.
  2. Click Add. A new rule is added to the list.
  3. Under Convert from group, choose what criteria a field should fulfill to match the rule. You can add criteria on schema, table, and field name as well as the data type. In the list of operators for the data type, you can click on "<Unknown>" to match data types that are not compatible with SQL Server.
  4. Under Convert to, click on the data type you want to convert the matching fields to in the Data type list. Adjust any settings for the data type you have selected.
  5. Click OK.
  6. Right-click on the data source and click Synchronize Data Source to apply the overrides.
Ordering data type overrides
Data type overrides are processed for each individual table. The first override from the top that matches the field is applied, and any other matches are ignored. Follow the steps below to order the overrides.
  2. Click on the override you want to reorder in the list and click on Move Up or Move Down to move the override up or down, respectively.
Note: The default rule that matches any unknown data types cannot be reordered. However, you can edit the data type it converts to. The purpose of this rule is to ensure that all fields end up with a data type SQL Server can handle.
Query Tables
When you connect to a data source in TimeXtender, you can simply use the read objects feature to list the content of the source and pick the tables and fields you want to use in your solution.
However, some AnySource providers allow you to connect to a data source, but cannot list its contents. In other cases, it is simply useful to be able to create a table that does not already exist on a data source, from a query. To enable you to use these data sources in TimeXtender, we have included the Query Tables feature. While the SQL behind ordinary tables is created by TimeXtender, you write the query that brings query tables to life.
The following data sources and adapters support the query tables feature:
  • AnySource adapter
  • Dynamics AX adapter
  • Dynamics Business Central (NAV) adapter
  • SQL data source
Adding Query Tables
To add a query table, follow the steps below.
  1. Connect to a data source using one of the supported data sources or adapters.
  2. Right-click the data source, click Data Source Settings, and click the Query Table tab.
  3. Click Add. A new table is added to the list.
  4. In the Name box, type a name for the table.
  5. (Optional) In the Schema box, type a schema to use.
  6. In Query, enter the query you want to use for creating the table. The query should contain a SELECT statement and follow the syntax required by the source.
  7. Select Subquery needed if you are using an alias in your query. Otherwise, selection rules will fail.
  8. Repeat steps 3-6 to add the tables you need and click OK.
  9. Right-click the data source and click Read Objects from Data Source. The tables are listed in the panel on the right-hand side of TimeXtender and can be included in the project like any other table.
Handling Accounts in Dynamics Business Central (NAV)
When you create query tables for Dynamics Business Central (NAV), you will have to consider how you handle accounts.
To get data from one account, remember the account in the FROM part of your statement:
SELECT * FROM [dbo].[MyCompany$MyTable]
To get data from multiple accounts, in the same way the Dynamics Business Central (NAV) Adapter does it, you can use placeholders:
SELECT * {0} FROM [dbo].[{1}$MyTable]
TimeXtender will replace the digits in curly brackets during execution to create the following statement for each account:
SELECT
* , CAST(‘MyCompany’ AS nvarchar(30)) AS (DW_Account)
FROM
Template Data Sources
If you have more than one data source with an identical data structure, you can connect all of them and use them as if they were one and the same. This feature is known as template data sources.
Adding an Additional Connection
Once you have added the first of the identical data sources as usual, you can add the additional data sources to the first data source. Since all of the data sources will have a similar data structure, it does not matter which one is added first.
To add an additional connection, follow the steps below.
  1. Right-click a data source and click Add <data source> Data Source.
    An Add <data source> Data Source window appears.
  2. Configure this second data source with the necessary parameters. This additional data source will then appear under the original data source in an Additional Connections folder.
When tables and fields are added to the data source, these changes will seamlessly be applied to all of the data sources that are under Additional Connections.
The "DW_SourceCode" field on tables on the data source contains the name of the source from which the row was copied. If you have a setup like the one displayed above with two sources, "SQL" and "SQL2", a table on this source would look something like the list below.
Selection Templates
Once you have selected all the tables you need from a data source, added primary keys, and set up incremental load, you can export all this information to a selection template. The template can then be applied to another data source in the same or another project. The data sources do not need to be identical.
Selection templates are stored in XML format.
Exporting a selection template
To export a selection template
  • Right-click a data source, click Selection Template, and click Export. In the window that appears, choose a file name and folder and click Save.
The tables and fields selected, the primary keys chosen, and the incremental load setup are saved in the exported file.
Importing a Selection Template
To import and apply a selection template to a data source, follow the steps below.
  1. Right-click the data source, click Selection Template, and click Import. The Import Selection Template window opens.
  2. Click Browse to find and select the template to import.
  3. Under Apply the following details from the template, remove the check mark from any parts of the template you do not want to apply. If you remove the check mark from Tables and fields, but keep Primary keys and/or Incremental Load Setup selected, these settings will be applied to the tables and fields already selected from the data source.
  4. Click OK.
Changing Data Source Providers
If you have moved your data to a new database, e.g., from Oracle Database to Microsoft SQL Server, you do not have to add a new data source to reflect this. Instead, you can change the type of your existing data source in TimeXtender with the change provider feature.
To change the provider for a data source
  • Right-click the data source, click on Change Provider, and click on the database you want to change provider to. A connection settings window appears. Refer to the section on the relevant data source in this user guide to learn more about the settings.
